User-designed web services to support heterogeneous biological data retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Marie-Dominique Devignes
Hervé de Palma
  • Fonction : Auteur
Laurent Pierron
Biological data retrieval from web resources often necessitates multi-step access to several information sources. Web services are being developed to interact in a unified manner with heterogeneous databases. Composition of web services is then required to chain several elementary queries. However, web services are not yet available for any data sources thus limiting the scope of such strategy. The X-collect generic application has been designed to execute user-defined multi-step scenarios. Demos can be scheduled at the workshop. Encapsulation into web services makes such user scenarios re-usable and available for invocation by any application. Demos can be scheduled at the workshop. Work in progress deals with metadata registries to facilitate databases and/or web services discovery.
Fichier non déposé
inria-00000419 , version 1 (10-10-2005)
  • HAL Id : inria-00000419 , version 1
Marie-Dominique Devignes, Hervé de Palma, Laurent Pierron, Lionel Domenjoud, Malika Smaïl-Tabbone. User-designed web services to support heterogeneous biological data retrieval. First International Workshop on workflows management: new abilities for the biological information overflow - NETTAB 2005, Oct 2005, Naples, Italy, pp.27-34. ⟨inria-00000419⟩
135 Consultations
0 Téléchargements
