A. , J. And-painter, and J. , Efficient sort-last rendering using compression-based image compositing, Proc. of the 2nd Eurographics Work. on Parallel Graphics and Visualization, 1998.
F. , S. And, and A. Kaufman, Massive volume rendering on a volume visualization cluster, 2004.
H. , A. And-moll, and L. , Scalable distributed visualization using off-the-shelf components, Proc. of the 1999 IEEE Symp. on Parallel Visualization and Graphics, 1999.
H. , G. Houston, M. Ng, R. Frank, R. Ahern et al., Chromium: a streamprocessing framework for interactive rendering on clusters, Proc. of SIGGRAPH '02, 2002.
K. , Y. Leigh, J. Xiong, C. And-murata, and T. , A sort-last rendering system over an optical backplane, 2004.
L. , T. Raghavendra, C. S. And-nicholas, and J. , Image composition schemes for sort-last polygon rendering on 2d mesh multicomputers, IEEE Transactions on Visualization and Computer Graphics, vol.2, p.3, 1996.
L. , S. Moll, L. Shand, M. Breen, D. And-heirich et al., Scalable interactive volume rendering using off-theshelf components, Proc. of the IEEE 2001 Symp. on parallel and large-data visualization and graphics, 2001.
M. , K. Painter, J. S. Hansen, C. D. And-krogh, and M. F. , Parallel volume rendering using binary-swap compositing, IEEE Comput. Graph. Appl, vol.14, p.4, 1994.
M. , L. Shand, M. And-heirich, and A. , Sepia: Scalable 3D compositing using PCI Pamette, Proc. of the Seventh Annual IEEE Symp. on Field-Programmable Custom Computing Machines, 1999.
M. , S. Cox, M. Ellsworth, D. And-fuchs, and H. , A sorting classification of parallel rendering, IEEE Comput. Graph. Appl, vol.14, p.4, 1994.
M. , K. And-thompson, and D. , From cluster to wall with VTK, Proc. of IEEE 2003 Symp. on Parallel and Large-Data Visualization and Graphics, 2003.
M. , K. Wylie, B. And-pavlakos, and C. , Sort-last parallel rendering for viewing extremely large data sets on tile displays, Proc. of IEEE 2001 Symp. on Parallel and Large-Data Visualization and Graphics, 2001.
M. , S. Ogata, M. Ma, K. Koshizuka, K. Kaji-hara et al., Nextgeneration visual supercomputing using PC clusters with volume graphics hardware devices, Proc. of the 2001 ACM/IEEE conf. on Supercomputing, 2001.
N. , J. Kukimoto, N. Sakamoto, N. Hazama, H. Watashiba et al., Hybrid hardware-accelerated image composition for sort-last parallel rendering on graphics clusters with commodity image compositor, IEEE/SIGGRAPH Symp. on Volume Visualization and Graphics, 2004.
R. , E. And-hansen, and C. , A comparison of parallel compositing techniques on shared memory architectures, Proc. of the Third Eurographics Work. on Parallel Graphics and Visualisation, 2000.
S. , R. Funkhouser, T. And-li, and K. , Parallel rendering with k-way replication, Proc. of the IEEE 2001 Symp. on Parallel and Large-data Visualization and Graphics, 2001.
S. , K. Kobayashi, Y. And-nakamura, and T. , Differential coding scheme for efficient parallel image composition on a PC cluster system, Parallel Comput, vol.30, issue.2, 2004.
S. , G. Eldridge, M. Patterson, D. Webb, A. Berman et al., Lightning-2: a high-performance display subsystem for PC clusters, Proc. of SIGGRAPH '01, 2001.
S. , A. Ma, K. Lum, E. B. Ahrens, J. And-patch-ett et al., SLIC: Scheduled linear image compositing for parallel volume rendering, IEEE Symp, 2003.
S. , M. Magallon, M. Weiskopf, D. Guthe, S. And-ertl et al., Hierarchical visualization and compression of large volume datasets using GPU clusters, Eurographics Symp. on Parallel Graphics and Visualization, 2004.
T. , A. Ino, F. And-hagihara, and K. , An improved binaryswap compositing for sort-last parallel rendering on distributed memory multiprocessors, Parallel Comput, vol.29, pp.11-12, 2003.
Y. , D. , Y. , J. And, C. et al., Efficient compositing methods for the sort-last-sparse parallel volume rendering system on distributed memory multicomputers, J. Supercomput, vol.18, issue.2, 2001.
Z. , X. Bajaj, C. And-blanke, and W. , Scalable isosurface visualization of massive datasets on cots clusters, Proc. of the IEEE 2001 Symp. on Parallel and Large-data Visualization and Graphics, 2001.
