An Architecture for the Interoperability of Workflow Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Salah Hamri
  • Fonction : Auteur
Mahmoud Boufaida
  • Fonction : Auteur
Nacer Boudjlida
  • Fonction : Auteur
  • PersonId : 830690
The goal of this work is to contribute to the field of interoperability of Workflow models. To achieve interoperability, we have built a generic architecture that addresses three levels of abstraction: a common meta-model that the Workflow models must share, a common model that they enact collectively, and a common data model whose management is shared. So, the approach we have adopted is based on a strategy of uniformity to solve the problems related to the semantic, syntactic and execution platform heterogeneity. The common meta-model gathers the common concepts that are shared between Workflow models and it defines their semantics. Common concepts (activity, event, etc.) that are extracted from different formalisms used in the field of business process (or Workflow) allow us to instantiate a canonical model that describes only common parts (activities, artifacts). As for the common data model, it is instantiated by the common model. For the control interoperability, we have adopted an approach that deals with a flexible connection mechanism based on events through a connection server. This approach can be implemented above any interoperability platform (CORBA, EJB, etc.). Moreover, the shared canonical model that we have proposed is generic, simple and re-usable.
Fichier non déposé
inria-00000446 , version 1 (17-10-2005)
Salah Hamri, Mahmoud Boufaida, Nacer Boudjlida. An Architecture for the Interoperability of Workflow Models. 1st International ACM Workshop on Interoperability of Heterogeneous Information Systems - IHIS'05, Oct 2005, Bremen/Germany, pp.31-38, ⟨10.1145/1096967.1096975⟩. ⟨inria-00000446⟩
109 Consultations
0 Téléchargements
