MARKERLESS HUMAN MOTION CAPTURE FOR GAIT ANALYSIS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Jamal Saboune
  • Fonction : Auteur
  • PersonId : 830761
The aim of our study is to detect balance disorders and a tendency towards the falls in the elderly, knowing gait parameters. In this paper we present a new tool for gait analysis based on markerless human motion capture, from camera feeds. The system introduced here, recovers the 3D positions of several key points of the human body while walking. Foreground segmentation, an articulated body model and particle filtering are basic elements of our approach. No dynamic model is used thus this system can be described as generic and simple to implement. A modified particle filtering algorithm, which we call Interval Particle Filtering, is used to reorganise and search through the model's configurations search space in a deterministic optimal way. This algorithm was able to perform human movement tracking with success. Results from the treatment of a single cam feeds are shown and compared to results obtained using a marker based human motion capture system.
2064_Saboune_J.pdf (300.16 Ko) Télécharger le fichier
inria-00000476 , version 1 (21-10-2005)
inria-00000476 , version 2 (21-10-2005)
Jamal Saboune, François Charpillet. MARKERLESS HUMAN MOTION CAPTURE FOR GAIT ANALYSIS. EMBEC 05, Nov 2005, Pragues. ⟨inria-00000476v1⟩
128 Consultations
291 Téléchargements
