Conference papers
Mining Workflow Recovery From Event Based Logs
Walid Gaaloul 1 Claude Godart 1
1 ECOO - Environment for cooperation
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Handling workflow transactional behavior remains a main problem to ensure a correct and reliable execution. It is obvious that the discovery, and the explanation of this behavior, would enable to better understand and control workflow recovery. Unfortunately, previous workflow mining works have concentrated their efforts on control flow aspects. Although powerful, these proposals are found lacking in functionalities and performance when used to discover workflow transactional behavior. In this paper, we describe mining techniques, which are able to discover a workflow model, and to improve its transactional behavior from event based logs. First, we propose an algorithm to discover workflow patterns. Then, we propose techniques to discover activities transactional dependencies that allow us to mine workflow recovery techniques. Finally, based on this mining step, we use a set of rules to improve workflow design.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00000482
Contributor : Walid Gaaloul Connect in order to contact the contributor
Submitted on : Saturday, October 22, 2005 - 10:49:05 AM
Last modification on : Friday, February 4, 2022 - 3:22:08 AM
Links full text
Identifiers
Citation
Walid Gaaloul, Claude Godart. Mining Workflow Recovery From Event Based Logs. Third International Conference on Business Process Management - BPM'05, Sep 2005, Nancy, France., pp.169-185, ⟨10.1007/11538394_12⟩. ⟨inria-00000482⟩
Share
Metrics
Record views
120
