Business Process Intelligence : Discovering and Improving Transactional behavior of Composite Services From Logs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Walid Gaaloul
One of the main features that makes Web services a promising technology for automating B2B interactions is the ability to dynamically combine a set of services into a new value added composite Web services (CS). However, a main problem that remains is how to ensure a correct and reliable execution. This paper presents a set of techniques to improve CS transactional behavior for a better failures handling. Basically, we propose a set of mining techniques to discover CS model and its transactional behavior from logs. Then, based on this mining step, we use a set of rules to improve its design. We refer to this set of techniques as the Business Process Intelligence (BPI) techniques suite.
Fichier non déposé
inria-00000485 , version 1 (22-10-2005)
  • HAL Id : inria-00000485 , version 1
Walid Gaaloul. Business Process Intelligence : Discovering and Improving Transactional behavior of Composite Services From Logs. Doctoral symposium in INTEROP-ESA'05 - First International Conference on Interoperability of Enterprise Software and Applications, Feb 2005, Geneva/Switzerland. ⟨inria-00000485⟩
55 Consultations
0 Téléchargements
