A schedulability analysis of an IEC 61499 control application - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper deals with the temporal correctness of control applications designed using the component-based standard IEC 61499. In this standard, a function block is defined as an event trigger component containing its own data. To validate the temporal behavior of an application, we have to take into account its scheduling on the execution support. We propose an abstraction of the component behavior taking into account all its possible executions. Moreover, we propose to verify the temporal correctness of the application with regard to global temporal properties (end to end delays). Thanks to such characterization, we show that it is possible to check deadlines for the application to ensure its correctness. To reach this goal, we transform the application into a dependant tasks model(Copyright © 2005 IFAC).
Autre [cs.OH]
Fichier non déposé
inria-00000492 , version 1 (18-11-2005)
  • HAL Id : inria-00000492 , version 1
Mohamed Khalgui, Xavier Rebeuf, Françoise Simonot-Lion. A schedulability analysis of an IEC 61499 control application. FeT 2005 - 6th IFAC International Conference on Fieldbus Systems and their Applications, Nov 2005, Puebla, Mexico. ⟨inria-00000492⟩
120 Consultations
0 Téléchargements
