Applying Evolutionary Optimisation to Robot Obstacle Avoidance - Archive ouverte HAL Access content directly
Conference Papers Year : 2004
(1) , (2) , (2) , (1)
1
2
This paper presents an artificial evolutionbased method for stereo image analysis and its application to real-time obstacle detection and avoidance for a mobile robot. It uses the Parisian approach, which consists here in splitting the representation of the robot's environment into a large number of simple primitives, the "flies", which are evolved following a biologically inspired scheme and give a fast, low-cost solution to the obstacle detection problem in mobile robotics.
Pauplin_ISCIIA04.pdf (422.98 Ko) Télécharger le fichier
Dates and versions
inria-00000494 , version 1 (24-10-2005)
Identifiers
Cite
Olivier Pauplin, Jean Louchet, Evelyne Lutton, Michel Null Parent. Applying Evolutionary Optimisation to Robot Obstacle Avoidance. ISCIIA 2004, Dec 2004, Haikou, Chine. ⟨inria-00000494⟩
Collections
INRIA INRIA2
102 View
69 Download
Share
