Applying Evolutionary Optimisation to Robot Obstacle Avoidance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This paper presents an artificial evolutionbased method for stereo image analysis and its application to real-time obstacle detection and avoidance for a mobile robot. It uses the Parisian approach, which consists here in splitting the representation of the robot's environment into a large number of simple primitives, the "flies", which are evolved following a biologically inspired scheme and give a fast, low-cost solution to the obstacle detection problem in mobile robotics.
Pauplin_ISCIIA04.pdf (422.98 Ko) Télécharger le fichier
inria-00000494 , version 1 (24-10-2005)
Olivier Pauplin, Jean Louchet, Evelyne Lutton, Michel Null Parent. Applying Evolutionary Optimisation to Robot Obstacle Avoidance. ISCIIA 2004, Dec 2004, Haikou, Chine. ⟨inria-00000494⟩
Collections
INRIA INRIA2
113 Consultations
74 Téléchargements
