Reliable Web Services Composition using a Transactional Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Sami Bhiri
  • Fonction : Auteur
  • PersonId : 755745
  • IdRef : 093328702
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
Olivier Perrin
  • Fonction : Auteur
  • PersonId : 830785
Web services are a key technology for automating inter-organizational interactions. Enterprises can externalise parts of their business processes using them. Then they can dynamically combine existing services to offer value added composite services (CS). One remaining problem is how to ensure a correct composition and a reliable execution of a CS with regards to partners transactional requirements. In this paper, we present a transactional approach to ensure the failure atomicity of CS required by partners. Partners specify their CS and the requested failure atomicity. Then, we use a set of rules to validate the composite service with regards to designers transactional requirements.
Fichier non déposé
inria-00000503 , version 1 (25-10-2005)
Sami Bhiri, Claude Godart, Olivier Perrin. Reliable Web Services Composition using a Transactional Approach. 2005 IEEE International Conference on e-Technology, e-Commerce and e-Service EEE 2005, Mar 2005, Hong-Kong/Chine, pp.15-21, ⟨10.1109/EEE.2005.113⟩. ⟨inria-00000503⟩
137 Consultations
0 Téléchargements
