HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Self-organizing Map Initialization
Mohammed Attik 1, 2 Laurent Bougrain 1 Frédéric Alexandre 1
1 CORTEX - Neuromimetic intelligence
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The solution obtained by Self-Organizing Map (SOM) strongly depends on the initial cluster centers. However, all existing SOM initialization methods do not guarantee to obtain a better minimal solution. Generally, we can group these methods in two classes: random initialization and data analysis based initialization classes. This work proposes an improvement of linear projection initialization method. This method belongs to the second initialization class. Instead of using regular rectangular grid our method combines a linear projection technique with irregular rectangular grid. By this way the distribution of results produced by the linear projection technique is considred. The experiments confirm that the proposed method gives better solutions compared to its original version.
Complete list of metadata
https://hal.inria.fr/inria-00000622
Contributor : Mohammed Attik Connect in order to contact the contributor
Submitted on : Thursday, November 10, 2005 - 9:41:19 AM
Last modification on : Friday, February 4, 2022 - 3:34:56 AM
Links full text
Identifiers
Collections
Citation
Mohammed Attik, Laurent Bougrain, Frédéric Alexandre. Self-organizing Map Initialization. 15th International conference on Artificial Neural Networks - ICANN 2005, Sep 2005, Warsaw/Poland, pp.357--362, ⟨10.1007/11550822_56⟩. ⟨inria-00000622⟩
Share
Metrics
Record views
378
