Model of multi-modal cortical processing: Coherent learning in self-organizing modules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neural Networks Année : 2005
Olivier Ménard
  • Fonction : Auteur
  • PersonId : 830966
Hervé Frezza-Buet
In this paper (An abbreviated version of some portions of this article appeared in reference Menard and Frezza-Buet (Menard, O., & Frezza-Buet, H. (2004). Rewarded multi-modal neuronal self-organization: Example of the arm reaching movement. In: Proceedings of international conference on advances in intelligent systems theory and application.), as part of the IJCNN 2005 conference proceedings, published under the IEEE copyright.), an original self-organizing model is presented, with experiments highlighting its ability to be used in different frameworks, as phonetic coding dependent on semantics and arm-reaching. The model relies on the coupling of the learning processes that stand at different self-organizing modules, and exhibits dynamics that can be discussed in terms of the binding of different modalities, scattered over the different modules. Such a binding property is based on an emerging constraint of keeping consistency between the modules. This process is induced by partial connectivity and appropriate neural field competition mechanisms.
Fichier non déposé
inria-00000636 , version 1 (10-11-2005)
  • HAL Id : inria-00000636 , version 1
Olivier Ménard, Hervé Frezza-Buet. Model of multi-modal cortical processing: Coherent learning in self-organizing modules. Neural Networks, 2005, 18 (5-6), pp.646--655. ⟨inria-00000636⟩
66 Consultations
0 Téléchargements
