Abstract : This paper presents a novel approach to identify complex shapes based on the Radon transform. We propose an adaptation of Radon transform called $\mathcal R$-transform which is invariant to common geometrical transformations. Moreover, to improve the uniqueness of the approach, a binary shape is projected into the Radon space for different levels of the Chamfer distance transform. The accuracy and the efficiency of the proposed algorithm in the presence of a variety of transformations are evaluated within a shape recognition process.
Salvatore Tabbone, Laurent Wendling, Jean-Pierre Salmon. A new shape descriptor defined on the Radon transform. Computer Vision and Image Understanding, Elsevier, 2006, 102 (1), pp.42--51. ⟨10.1016/j.cviu.2005.06.005⟩. ⟨inria-00000643⟩
