Grid Computing: Software environments and Tools, chapter ASSIST as a Research Framework for High-Performance Grid Programming Environments, 2004. ,
The CCA core specification in a distributed memory SPMD framework, Concurrency and Computation: Practice and Experience, vol.14, issue.5, pp.323-345, 2002. ,
The Grid Application Toolkit: Toward Generic and Easy Application Programming Interfaces for the Grid, Proc. of the IEEE, 2005. ,
DOI : 10.1109/JPROC.2004.842755
Toward a common component architecture for high-performance scientific computing, Proceedings. The Eighth International Symposium on High Performance Distributed Computing (Cat. No.99TH8469), pp.13-22, 1999. ,
DOI : 10.1109/HPDC.1999.805289
Users' guide to NetSolve v1.4.1. Innovative Computing Dept, 2002. ,
From Distributed Objects to Hierarchical Grid Components, International Symp. on Distributed Objects and Applications (DOA), number 2888 in LNCS, pp.1226-1242, 2003. ,
DOI : 10.1007/978-3-540-39964-3_78
A comparison study of static mapping heuristics for a class of meta-tasks on heterogeneous computing systems, Proceedings. Eighth Heterogeneous Computing Workshop (HCW'99), pp.15-29, 1999. ,
DOI : 10.1109/HCW.1999.765093
A Scalable Approach to Network Enabled Servers, Proc. of the 8th International Euro-Par Conference, pp.907-910, 2002. ,
DOI : 10.1007/3-540-45706-2_128
URL : https://hal.archives-ouvertes.fr/inria-00072087
The AppLeS Parameter Sweep Template: User-level middleware for the grid, Proc. of the IEEE/ACM SuperComputing Conference (SC'2000), pp.60-78, 2000. ,
Grid information services for distributed resource sharing, Proceedings 10th IEEE International Symposium on High Performance Distributed Computing, pp.181-194, 2001. ,
DOI : 10.1109/HPDC.2001.945188
A resource management architecture for metacomputing systems, IPPS/SPDP'98 Workshop on Job Scheduling Strategies for Parallel Processing, pp.62-82, 1998. ,
DOI : 10.1007/BFb0053981
The Grid: Blueprint for a New Computing Infrastructure, chapter Computational Grids, pp.15-51, 1998. ,
Condor-G: a computation management agent for multi-institutional grids, Proceedings 10th IEEE International Symposium on High Performance Distributed Computing, pp.55-63, 2001. ,
DOI : 10.1109/HPDC.2001.945176
ICENI: Optimisation of component applications within a Grid environment, Parallel Computing, vol.28, issue.12, pp.1753-1772, 2002. ,
DOI : 10.1016/S0167-8191(02)00187-4
Using MPI: Portable Parallel Programming with the Message-Passing Interface, 1999. ,
MPICH-G2: a grid-enabled implementation of the message passing interface, Journal of Parallel and Distributed Computing (JPDC), vol.63, issue.5, pp.551-563, 2003. ,
XCAT3: A Framework for CCA Components as OGSA Services, Ninth International Workshop on High-Level Parallel Programming Models and Supportive Environments, 2004. Proceedings., pp.90-97, 2004. ,
DOI : 10.1109/HIPS.2004.1299194
GRMS user guide version 1.9.6, 2005. ,
Deploying CORBA Components on a Computational Grid: General Principles and Early Experiments Using the Globus Toolkit, Proc. of the 2nd International Working Conference on Component Deployment number 3083 in LNCS, pp.35-49, 2004. ,
DOI : 10.1007/978-3-540-24848-4_3
URL : https://hal.archives-ouvertes.fr/inria-00071435
A Network Topology Description Model for Grid Application Deployment, Fifth IEEE/ACM International Workshop on Grid Computing, pp.61-68, 2004. ,
DOI : 10.1109/GRID.2004.2
URL : https://hal.archives-ouvertes.fr/inria-00070773
A software architecture for automatic deployment of CORBA components using grid technologies, Proc. of the 1st Francophone Conference On Software Deployment and (Re)Configuration, pp.187-192, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00003294
Description and packaging of MPI applications for automatic deployment on computational grids, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000082
A Parallel Corba Component Model for Numerical Code Coupling, International Journal of High Performance Computing Applications, vol.17, issue.4, pp.417-429, 2003. ,
DOI : 10.1177/10943420030174006
Matchmaking: distributed resource management for high throughput computing, Proceedings. The Seventh International Symposium on High Performance Distributed Computing (Cat. No.98TB100244), pp.140-146, 1998. ,
DOI : 10.1109/HPDC.1998.709966
The end-user and middleware APIs for GridRPC, Proc. of the Workshop on Grid Application Programming Interfaces, 2004. ,
Component Software: Beyond Object-Oriented Programming ,
Condor and the Grid, Grid Computing: Making the Global Infrastructure a Reality, 2002. ,
DOI : 10.1002/0470867167.ch11
