Linear Segmentation of Discrete Curved into blurred Segments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Applied Mathematics Année : 2005
The concept of fuzzy segment is introduced, it allows the flexible segmentation of discrete curves, taking into account noise. Relying on an arithmetic definition of discrete lines [Réveilles 1991], it generalizes such lines, admitting that some points are missing. Thus, a larger class of objects is considered. A very efficient linear detection algorithm for fuzzy segments and its application to curve segmentation are presented.
Fichier non déposé
inria-00000655 , version 1 (10-11-2005)
  • HAL Id : inria-00000655 , version 1
Isabelle Debled-Rennesson, Jean-Luc Rémy, Jocelyne Rouyer-Degli. Linear Segmentation of Discrete Curved into blurred Segments. Discrete Applied Mathematics, 2005, 151 (1-3), pp.122--137. ⟨inria-00000655⟩
105 Consultations
0 Téléchargements
