Complexity of scheduling problems with multi-purpose machines, Annals of Operational Research, vol.70, pp.57-73, 1997. ,
Robust Discrete Optimization and its applications, 1997. ,
DOI : 10.1007/978-1-4757-2620-6
On Preemptive Scheduling of Unrelated Parallel Processors by Linear Programming, Journal of the ACM, vol.25, issue.4, pp.612-619, 1978. ,
DOI : 10.1145/322092.322101
Branch-and-Bound Methods: A Survey, Operations Research, vol.14, issue.4, pp.699-719, 1966. ,
DOI : 10.1287/opre.14.4.699
A fast algorithm for building lattices, Information Processing Letters, vol.71, issue.5-6, pp.199-204, 1999. ,
DOI : 10.1016/S0020-0190(99)00108-8
Scheduling : Theory, Algorithms and Systems Ordonnancement en milieu incertain , mise en oeuvre d'une démarche robuste Etude de robustesse : configuration d'un parc de machines partiellement multifonctions, Journal Européen des Systèmes Automatisés, vol.34, pp.373-395, 2003. ,
DOI : 10.3166/jesa.38.373-395
Multivariable Feedback Control : Analysis and Design, 1996. ,
On the calculation of the stability radius of an optimal or an approximate schedule, Annals of Operations Research, vol.83, pp.213-252, 1998. ,
DOI : 10.1023/A:1018960030420
