Damper with magnetorheological suspension, Journal of Magnetism and Magnetic Materials, vol.241, issue.2-3, pp.196-200, 2002. ,
DOI : 10.1016/S0304-8853(02)00009-4
Landing Gear Integration in Aircraft Conceptual Design Report of Multidisciplinary Analysis and Design Center for Advanced Vehicles, pp.24061-0203, 1996. ,
Modélisation et Optimisation de l'atterrissage d'un hélicoptère, 2004. ,
Testing of Semi-active Landing Gear Control for a General Aviation Aircraft, Journal of Aircraft, vol.37, issue.4, 2000. ,
Evaluation of a landing gear semi-active control system for complete aircraft landingDesign of a control law for a magneto-rheological suspension, Proc. European Control Conference, 2003. ,
Design of a control law for a semiactive suspension system using a solenoid valve damper, Proceedings of the 2004 IEEE International Conference on Control Applications, 2004., 2004. ,
DOI : 10.1109/CCA.2004.1387582
A controlled friction damper for vehicle applications, Control Engineering Practice, vol.12, issue.4, pp.431-443, 2004. ,
DOI : 10.1016/S0967-0661(03)00119-9
Modeling and Validation of a Navy A6-Intruder Actively Controlled Landing Gear System, Langley Research Center, 1999. ,
Control of an Active Vehicle Suspension Using Electromagnetic Motor, ICCAS2003, 2003. ,
Integrated Design Process for the Development of Semi-Active Landing Gears for Transport Aircraft, Thesis Institut für Flugmechanik und Flugregelung der Universität Stuttgart, p.122, 2000. ,
Origine et contrôle des vibrations mécaniques, Hermes, 2003. ,
Linear and non-linear skyhook damping control laws for active railway suspensions, Control Engineering Practice, vol.7, issue.7, pp.843-850, 1999. ,
DOI : 10.1016/S0967-0661(99)00048-9
Nonlinear Design of Active Suspensions, 34th IEEE Conference on Decision and Control, pp.11-13, 1995. ,
Adaptative aircraft shock absorbers ,
Overview of Landing Gear Dynamics, Journal of Aircraft, vol.38, issue.1, 1999. ,
DOI : 10.2514/2.2744
A class of proportional-integral sliding mode control with application to active suspension system, Systems and Control Letters 51, pp.217-223, 2004. ,
DOI : 10.1016/j.sysconle.2003.08.007
Theory of vibration, 1996. ,
