Decomposition of domains based on the micro-structure of finite constraint-satifaction problems, Proceedings of the Eleventh National Conference on Artificial Intelligence, 1993. ,
Sur une généralisation des graphes triangulés et son application pour la décomposition de domaines dans les csp, Actes JNPC, 2003. ,
Increasing tree search efficiency for constraint satisfaction problems, Artificial Intelligence, vol.14, issue.3, p.14, 1980. ,
DOI : 10.1016/0004-3702(80)90051-X
Kjaerulff : Triangulation of graphs -algorithms giving small total state space, 1990. ,
A wide-range efficient algorithm for minimal triangulation, Proceedings of SO- DA'99 SIAM Conference, 1999. ,
A generalization of chordal graphs and the maximum clique problem, Information Processing Letters, vol.62, issue.2, p.62, 1997. ,
DOI : 10.1016/S0020-0190(97)00044-6
Domain decomposition for parallel resolution of constraints satisfaction problems with openmp, Proceedings of the second European Workshop on OpenMP, 2000. ,
Contradicting conventional wisdom in constraint satisfaction, Proceedings of the Second International Workshop on Principles and Practice of Constraint Programming, PPCP'94, 1994. ,
DOI : 10.1007/3-540-58601-6_86
