Change detection for nonlinear systems : A particle filtering approach Hybrid consensus theoric classification, Proceedings of 2002 American Control Conference, pp.833-843, 1997. ,
A bayesian sampling approch to decision fusion using hierarchical models, IEEE Transactions on signal processing, issue.8, pp.501809-1818, 2002. ,
Adaptive fusion of correlated local decisions, IEEE Transactions on Systems, Man and Cybernetics, Part C (Applications and Reviews), vol.28, issue.2, pp.276-281, 1998. ,
DOI : 10.1109/5326.669570
Allocating the weights in the linear opinion pool, Journal of Forecasting, vol.146, issue.1, pp.53-73, 1990. ,
DOI : 10.1002/for.3980090106
John Wiley and Sons publication. [Nikiforov, 1995] Nikiforov I. et Basseville M, Detection of Arupt Changes : Theory and Application, 1995. ,
On fusers that perfor better than best sensor, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.8, pp.904-909, 2001. ,
GLR TESTS FOR FAULT DETECTION OVER SLIDING DATA WINDOWS, IFAC Proceedings Volumes, vol.38, issue.1, 2004. ,
DOI : 10.3182/20050703-6-CZ-1902.00125
Distributed detection and data fusion The good, bad, and ugly : Distributed detection of a known signal in dependent gaussian noise, IEEE Transactions On Signal Processing, issue.12, pp.483266-3279, 1996. ,
A generalized likelihood ratio approach to the detection and estimation of jumps in linear systems, IEEE Transactions on Automatic Control, vol.21, issue.1, pp.108-112, 1976. ,
DOI : 10.1109/TAC.1976.1101146
On some unresolved issues in finding optimum distributed detection schemes, IEEE Transactions On Signal Processing, issue.12, pp.483280-3288, 2000. ,
