On the confluence of lambda-calculus with conditional rewriting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The confluence of untyped lambda-calculus with unconditional rewriting has already been studied in various directions. In this paper, we investigate the confluence of lambda-calculus with conditional rewriting and provide general results in two directions. First, when conditional rules are algebraic. This extends results of Muller and Dougherty for unconditional rewriting. Two cases are considered, whether beta-reduction is allowed or not in the evaluation of conditions. Moreover, Dougherty's result is improved from the assumption of strongly normalizing beta-reduction to weakly normalizing beta-reduction. We also provide examples showing that outside these conditions, modularity of confluence is difficult to achieve. Second, we go beyond the algebraic framework and get new confluence results using an extended notion of orthogonality that takes advantage of the conditional part of rewrite rules.
main.pdf (289.11 Ko) Télécharger le fichier
inria-00000729 , version 1 (31-08-2006)
inria-00000729 , version 2 (11-09-2006)
Frédéric Blanqui, Claude Kirchner, Colin Riba. On the confluence of lambda-calculus with conditional rewriting. Foundations of Software Science and Computation Structures, Mar 2006, Vienne/Autriche, ⟨10.1007/11690634_26⟩. ⟨inria-00000729v1⟩
123 Consultations
116 Téléchargements
