Integrated control and scheduling, 1999. ,
An introduction to control and scheduling co-design, Proceedings of the 39th IEEE Conference on Decision and Control (Cat. No.00CH37187), 2000. ,
DOI : 10.1109/CDC.2001.914701
Computer-Controlled Systems -Theory and Design, 1990. ,
Fixed priority preemptive scheduling: An historical perspective, Real-Time Systems, pp.173-198, 1995. ,
Analysis of preemptive periodic real-time systems using the (max, plus) algebra with applications in robotics, IEEE Transactions on Control Systems Technology, vol.10, issue.3, pp.368-380, 2002. ,
DOI : 10.1109/87.998024
URL : https://hal.archives-ouvertes.fr/inria-00100900
SynchronizatioN and LinearitY : An Algebra for Discrete Event Systems, Wiley Series in Probability and Mathematical Statistics, 1992. ,
Programmation et vérification de tâches robotiques multicadences, Master's thesis, 2001. ,
Weakly hard real-time systems, IEEE Transactions on Computers, vol.50, issue.4, pp.308-321, 2001. ,
DOI : 10.1109/12.919277
On model checking for real-time properties with durations, [1993] Proceedings Eighth Annual IEEE Symposium on Logic in Computer Science, 1993. ,
DOI : 10.1109/LICS.1993.287592
HRT-HOOD: A structured design method for hard real-time systems, Real-time Systems, vol.36, issue.1, 1995. ,
DOI : 10.1007/BF01245300
Towards modelling and verification of concurrent Ada programs using Petri-nets, Workshop on Software Engineering and Petri Nets, pp.115-134, 2000. ,
Integrated Control and Real-Time Scheduling, 2003. ,
Satyr and the nymph: Software archetype for real time robotics, IEEE-ACM Joint Computer Conference ,
Experimental evaluation of the fail-silent behavior of a distributed real-time run-time support built from COTS components, Proceedings International Conference on Dependable Systems and Networks, pp.304-313, 2001. ,
DOI : 10.1109/DSN.2001.941415
A Matlab toolbox for real-time and control systems co-design, Proceedings Sixth International Conference on Real-Time Computing Systems and Applications. RTCSA'99 (Cat. No.PR00306), pp.320-327, 1999. ,
DOI : 10.1109/RTCSA.1999.811266
TPAP, Electronic Notes in Theoretical Computer Science, vol.65, issue.6, 2002. ,
DOI : 10.1016/S1571-0661(04)80470-5
Decibility issues for Petri nets -a survey, Journal of Informatik Processing and Cybernetics, vol.30, issue.3, pp.143-160, 1994. ,
Real-time schedulability tests for preemptive multitasking, Real-Time Systems, vol.14, issue.1, pp.61-93, 1998. ,
DOI : 10.1023/A:1007993819750
Fault-tolerant static scheduling for real-time distributed embedded systems, Proceedings 21st International Conference on Distributed Computing Systems, 2001. ,
DOI : 10.1109/ICDSC.2001.919002
URL : https://hal.archives-ouvertes.fr/inria-00072638
A Concurrent and Compositional Petri Net Semantics of Preemption, Integrated Formal Methods, pp.318-337, 2000. ,
DOI : 10.1007/3-540-40911-4_19
URL : https://hal.archives-ouvertes.fr/hal-00114693
Scheduling algorithms for multiprogramming in hard real-time environment, Journal of the ACM, vol.20, issue.1, pp.40-61, 1973. ,
Performance specifications and metrics for adaptive real-time systems, Time Systems Symposium, 2000. ,
Mécanismes de synchronisation dans un système robotique réparti, Séminaire franco-brésilien sur les systèmes informatiques répartis, 1989. ,
Petri nets: Properties, analysis and applications, Proceedings of the IEEE, pp.541-580, 1989. ,
DOI : 10.1109/5.24143
Timing problems in real-time control systems, p.20, 1998. ,
Guest Editorial, -3), pp.115-128, 2000. ,
DOI : 10.1007/s11241-005-0501-2
Performance evaluation of asynchronous concurrent systems using Petri nets, IEEE Trans. on Software Engineering, vol.6, issue.5, pp.440-449, 1980. ,
Streamlining real-time controller design: from performance specifications to end-to-end timing constraints, IEEE Real Time Systems Symposium, 1997. ,
Managing complex temporal requirements in real-time control systems, Proceedings Ninth Annual IEEE International Conference and Workshop on the Engineering of Computer-Based Systems, 2002. ,
DOI : 10.1109/ECBS.2002.999828
Problem formulations for qos management in automatic control, 2000. ,
Priority inheritance protocols: an approach to real-time synchronization, IEEE Transactions on Computers, vol.39, issue.9, pp.1175-1185, 1990. ,
DOI : 10.1109/12.57058
Design and analysis of synchronization for real-time closed-loop control in robotics, IEEE Transactions on Control Systems Technology, vol.6, issue.4, pp.445-461, 1998. ,
DOI : 10.1109/87.701336
Computer-aided design of a generic robot controller handling reactivity and real-time control issues, IEEE Transactions on Control Systems Technology, vol.1, issue.4, pp.213-229, 1993. ,
DOI : 10.1109/87.260267
URL : https://hal.archives-ouvertes.fr/inria-00074872
Multireader and multiwriter asynchronous communication mechanisms, IEE Proceedings-Computer and Digital Techniques, pp.241-244, 1997. ,
DOI : 10.1049/ip-cdt:19971220
How to integrate precedence constraints and shared resources in real-time scheduling, IEEE Transactions on Computers, vol.43, issue.12, pp.1407-1412, 1994. ,
DOI : 10.1109/12.338100
Fundamentals of Implementing Real-Time Control Applications in Distributed Computer Systems, Real Time Systems, vol.14, issue.3, pp.219-250, 1998. ,
DOI : 10.1007/978-0-585-35223-7_2
A sample-induced delays in synchronous multirate systems, European Control Conference, pp.3276-3281, 2001. ,
