Conference papers
Analytic performance comparison of routing protocols in master-slave PLC networks
Gerd Bumiller 1 Liping Lu 2 Ye-Qiong Song 2
2 TRIO - Real time and interoperability
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In the wide area master-slave PLC (powerline communication) system, the source node cannot reach the destination node without packet relay. Due to the time-variable attenuation in the powerline, the communication distance cannot be defined. Two kind of dynamic repeater algorithms are developed, dynamic source routing and flooding based routing. In this paper, we use analytic approach to compare the performance of those two routing protocols. We give formulas to calculate the average duration of a polling cycle for each protocols. Then we present simulation results to bolster the results of our analysis. We use three metrics, which are bandwidth consumed for routing signaling, normalized routing load and average duration of a polling cycle to evaluate those routing protocols.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00000756
Contributor : Liping Lu Connect in order to contact the contributor
Submitted on : Wednesday, November 16, 2005 - 4:02:12 PM
Last modification on : Friday, February 4, 2022 - 3:23:50 AM
Long-term archiving on: : Monday, September 6, 2010 - 11:32:28 AM
Identifiers
Collections
Citation
Gerd Bumiller, Liping Lu, Ye-Qiong Song. Analytic performance comparison of routing protocols in master-slave PLC networks. 9th International Symposium on Power-Line Communications and Its Applications - ISPLC'2005, Apr 2005, Vancouver/Canada. ⟨inria-00000756⟩
Share
Metrics
Record views
140
Files downloads
223
