New interface
Book sections
Application of a Multi-Objective Evolutionary Algorithm to Topological Optimum Design
Abstract : The paper deals with multi-objective Topological Optimum Design (TOD) problems. Considered optimization criteria are the minimization of both the mass of the structure and its maximal displacement under a prescribed loading. Multi-objective evolutionary algorithm using Voronoi representation are applied on the cantilever plate, the popular benchmark problems of TOD. The results are discussed in the light of the single objective approaches used in previous works: whereas the quality of the result is very similar, the number of Finite Element Analyzes needed to obtain a full set of trade-off structures by the multi-objective method is more or less the same that needed to obtain only one solution using a single-objective algorithm with a limit on the maximal displacement: This makes multi-objective approach extremely interesting for solving real life TOD problems where the evaluation cost is usually quite high while the possibility of making of a well justified choice of definitive design is very important.
Document type :
Book sections
Complete list of metadata
https://hal.inria.fr/inria-00000848
Contributor : Marc Schoenauer Connect in order to contact the contributor
Submitted on : Thursday, November 24, 2005 - 4:14:36 PM
Last modification on : Thursday, February 3, 2022 - 11:16:05 AM
Long-term archiving on: : Friday, April 2, 2010 - 11:09:18 PM
Identifiers
  • HAL Id : inria-00000848, version 1
Collections
Citation
Hatem Hamda, Olga Roudenko, Marc Schoenauer. Application of a Multi-Objective Evolutionary Algorithm to Topological Optimum Design. I. C. Parmee. Adaptive Computing in Design and Manufacture V, Springer, pp.121-132, 2002, 978-1852336059. ⟨inria-00000848⟩
Share
Metrics
Record views
193
Files downloads
130
