EASEA : un langage de spécification pour les algorithmes évolutionnaires - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Evolutionary algorithms are not straightforward to implement and the lack of any specialised language forces users to write their algorithms in C, C++ or JAVA. However, most evolutionary algorithms follow a similar design, and the only really specific part is the code representing the problem to be solved. Therefore, it seems that nothing, in theory, could prevent a user from being able to design and run his evolutionary algorithm from a Graphic User Interface, without any other programming effort than the function to be optimised. Writing such a GUI rapidly poses the problem of saving and reloading the evolutionary algorithm on which the user is working, and translating the information into compilable code. This very much sounds like a specifying language and its compiler. The EASEA software was created on this purpose, and to our knowledge, it is the first and only usable compiler of a language specific to evolutionary algorithms. This reprot describes how EASEA has been designed and the problems which needed to be solved to achieve its implementation.
19_RR4218.pdf (268.95 Ko) Télécharger le fichier
inria-00000849 , version 1 (24-11-2005)
  • HAL Id : inria-00000849 , version 1
Pierre Collet, Marc Schoenauer, Evelyne Lutton, Jean Louchet. EASEA : un langage de spécification pour les algorithmes évolutionnaires. [Research Report] RR-4218, INRIA. 2001, pp.17. ⟨inria-00000849⟩
382 Consultations
491 Téléchargements
