A geologically-sound representation for evolutionary multi-objective subsurface identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
A new representation for evolutionary subsurface identification from surface or well geological data is proposed. It does not require any guess of the underlying fault structure by the expert, but generate geologically balanced layouts. The idea is to represent the subsurface as the combination of, first, a geologically initial set of horizontal layers and, second, fault parameters like shape and displacements. Based on volume and bed-length preservation, a morphogenesis process then gives the structure at present time. A first implementation of this representation is tested on an artificial geological inverse problem in foothills region: the fault locations and dips are considered as two different objectives, and the Epsilon-MOEA multi-objective evolutionary algorithm is applied. The first results show the efficiency of the chosen representation.
CEC8.pdf (744.4 Ko) Télécharger le fichier
inria-00000855 , version 1 (26-11-2005)
  • HAL Id : inria-00000855 , version 1
Vijay Pratap Singh, Marc Schoenauer, Michel Léger. A geologically-sound representation for evolutionary multi-objective subsurface identification. IEEE Congress on Evolutionary Computation - CEC'05, D. Corne, Sep 2005, Edinburgh - UK, pp.454-462. ⟨inria-00000855⟩
179 Consultations
213 Téléchargements
