Take it EASEA - Archive ouverte HAL Access content directly
Conference Papers Year : 2000
Take it EASEA
(1) , (1) , (2) , (3)
1
2
3
Evolutionary algorithms are not straightforward to implement and the lack of any specialised language forces users to reinvent the wheel every time they want to write a new program. Over the last years, evolutionary libraries have appeared, trying to reduce the amount of work involved in writing such algorithms from scratch, by offering standard engines, strategies and tools. Unfortunately, most of these libraries are quite complex to use, and imply a deep knowledge of object programming and C++. To further reduce the amount of work needed to implement a new algorithm, without however throwing down the drain all the man-years already spent in the development of such libraries, we have designed EASEA (acronym for EAsy Specification of Evolutionary Algorithms): a new high-level language dedicated to the specification of evolutionary algorithms. EASEA compiles .ez files into C++ object files, containing function calls to a chosen existing library. The resulting C++ file is in turn compiled and linked with the library to produce an executable file implementing the evolutionary algorithm specified in the original .ez file.
32_PPSNVI.pdf (221.35 Ko) Télécharger le fichier
Dates and versions
inria-00000875 , version 1 (29-11-2005)
Identifiers
  • HAL Id : inria-00000875 , version 1
Cite
Pierre Collet, Evelyne Lutton, Marc Schoenauer, Jean Louchet. Take it EASEA. PPSN VI, Sep 2000, Paris - France. ⟨inria-00000875⟩
148 View
184 Download
Share
