HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Integration of streaming services and TCP data transmission in the Internet
Abstract : We study in this paper the integration of elastic and streaming traffic on a same link in an IP network. We are specifically interested in the computation of the mean bit rate obtained by a data transfer. For this purpose, we consider that the bit rate offered by streaming traffic is low, of the order of magnitude of a small parameter \eps \ll 1 and related to an auxiliary stationary Markovian process (X(t)). Under the assumption that data transfers are exponentially distributed, arrive according to a Poisson process, and share the available bandwidth according to the ideal processor sharing discipline, we derive the mean bit rate of a data transfer as a power series expansion in \eps. Since the system can be described by means of an M/M/1 queue with a time-varying server rate, which depends upon the parameter \eps and process (X(t)), the key issue is to compute an expansion of the area swept under the occupation process of this queue in a busy period. We obtain closed formulas for the power series expansion in \eps of the mean bit rate, which allow us to verify the validity of the so-called reduced service rate at the first order. The second order term yields more insight into the negative impact of the variability of streaming flows.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00000898
Contributor : Philippe Robert Connect in order to contact the contributor
Submitted on : Friday, December 2, 2005 - 9:26:03 AM
Last modification on : Friday, February 4, 2022 - 3:19:41 AM
Long-term archiving on: : Friday, April 2, 2010 - 11:19:06 PM
Identifiers
Collections
Citation
Nelson Antunes, Christine Fricker, Fabrice Guillemin, Philippe Robert. Integration of streaming services and TCP data transmission in the Internet. Performance Evaluation, Elsevier, 2005, 62 (1-4), pp.263--277. ⟨10.1016/j.peva.2005.07.006⟩. ⟨inria-00000898⟩
Share
Metrics
Record views
51
Files downloads
103
