Parallel Computation. Models and Methods Bandwidth, space and computation efficient PRAM programming: The BSP approach, Proceedings of the SUP'EUR '96 Conference, 1996. ,
Designing broadcasting algorithms in the Postal Model for message passing systems, The 4th annual ACM symposium on parallel algorithms and architectures, pp.13-22, 1992. ,
The Paderborn University BSP (PUB) Library?Design, Implementation and Performance, 13th International Parallel Processing Symposium & 10th Symposium on Parallel and Distributed Processing, 1999. ,
Efficient Parallel Graph Algorithms For Coarse Grained Multicomputers and BSP, The 24th International Colloquium on Automata Languages and Programming, pp.390-400, 1997. ,
Faster optimal prefix sums and list ranking, Information and Computation, vol.81, issue.3, pp.128-142, 1989. ,
LogP: Towards a Realistic Model of Parallel Computation, 4th ACM SIGPLAN Symposium on principles and practice of parallel programming, 1993. ,
Scalable parallel computational geometry for coarse grained multicomputers, Int. J. on Comp. Geom, vol.6, issue.3, pp.379-400, 1996. ,
Echange de données pour le parallélismè a gros grain, 2004. ,
SSCRAP: An Environment for Coarse Grained Algorithms, Fourteenth IASTED International Conference on Parallel and Distributed Computing and Systems, pp.398-403, 2002. ,
SSCRAP: Soft Synchronized Computing in Rounds for Adequate Parallelization, 2004. ,
An experimental validation of the PRO model for parallel and distributed computation, 14th Euromicro Conference on Parallel, Distributed and Network based Processing, 2006. ,
Parallelism in random access machines, 10th ACM Symposium on Theory of Computing, pp.114-118, 1978. ,
PRO: a model for Parallel Resource-Optimal computation, 16th Annual International Symposium on High Performance Computing Systems and Applications. IEEE, pp.106-113, 2002. ,
Graph Coloring on a Coarse Grained Multiprocessor, Discrete Appl. Math, vol.131, issue.1, pp.179-198, 2003. ,
PRAM programming: Theory vs. Practice, Proceedings of 6th Euromicro Workshop on Parallel and Distributed Processing, 1998. ,
A new randomized sorting algorithm on the BSP model, 2001. ,
Direct Bulk-Synchronous Parallel Algorithms, Journal of Parallel and Distributed Computing, vol.22, pp.251-267, 1994. ,
Can a Shared-Memory Model Serve as a Bridging Model for Parallel Computation? Theory of, Computing Systems, vol.32, issue.3, pp.327-359, 1999. ,
Limits to Parallel Computation: P- Completeness Theory, 1995. ,
Portable List Ranking: an Experimental Study, ACM Journal of Experimental Algorithmics, vol.7, issue.7, 2002. ,
Handling Graphs According to a Coarse Grained Approach: Experiments with MPI and PVM, Recent Advances in Parallel Virtual Machine and Message Passing Interface, 7th European PVM/MPI Users' Group Meeting, pp.72-79, 1908. ,
parXXL: A Fine Grained Development Environment on Coarse Grained Architectures In Workshop on state-of-the-art in scientific and parallel computing (PARA'06), 2006. ,
BSPlib: The BSP programming library, Parallel Computing, vol.14, 1947. ,
The Block Distributed Memory Model, IEEE Transactions on Parallel and Distributed Systems, vol.8, issue.7, pp.830-840, 1996. ,
Parallel Algorithms for Shared-Memory Machines, Handbook of Theoretical Computer Science, pp.869-941, 1990. ,
A complexity theory of efficient parallel algorithms, Theoretical Computer Science, vol.71, issue.1, pp.95-132, 1990. ,
Models of parallel computation: A survey and synthesis, 28th HICSS, pp.61-70, 1995. ,
New classes for parallel complexity: A study of unification and other complete problems for P, IEEE Transactions on Computers C-35, vol.5, pp.403-418, 1986. ,
