KOALAB: A new method for regulatory motif search. Illustration on alternative splicing regulation in HIV-1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Discovering heterogeneous regulatory motifs remains a difficult problem in biological sequence analysis. In this context, statistical learning or pattern search techniques on their own have shown some limitations. However, significant benefits can be taken from their complementarity. We selected two state-of-the-art methods: a multi-class support vector machine (M-SVM) from the statistical learning domain associated with a performant discrete pattern matching algorithm grappe, and in- tegrated them into a web technology based graphical software: KOALAB (KOupled Algorithmic and Learning Approach for Biology)1 . We applied our method on motif discovery within nucleic acid sequences using experimental SELEX results as training database for the M-SVM. An application dealing with the search for splicing regulatory protein binding sites in HIV-1 genome shows the potential of such an approach.
EveiLarhRopeBillPeyr04.pdf (357.83 Ko) Télécharger le fichier
inria-00000915 , version 1 (08-12-2005)
  • HAL Id : inria-00000915 , version 1
Damien Eveillard, Abdelhalim Larhlimi, Delphine Ropers, Stéphanie Billaut, Sandrine Peyrefitte. KOALAB: A new method for regulatory motif search. Illustration on alternative splicing regulation in HIV-1. 5èmes Journées Ouvertes Biologie Informatique Mathématiques - JOBIM 2004, Jun 2004, Montréal, Canada. ⟨inria-00000915⟩
185 Consultations
111 Téléchargements
