A multi-scale constraint programming model of alternative splicing regulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2004
Alternative splicing is a key process in post-transcriptional regulation, by which different mature RNA can be obtained from the same premessenger RNA. The resulting combinatorial complexity contributes to biological diversity, especially in the case of the human immunodeficiency virus HIV-1. Using a constraint programming approach, we develop a model of the alternative splicing regulation in HIV-1. Our model integrates different scales (single site vs. multiple sites), and thus allows us to exploit several types of experimental data available to us.
inria-00000916 , version 1 (08-12-2005)
Damien Eveillard, Delphine Ropers, Hidde de Jong, Christiane Branlant, Alexander Bockmayr. A multi-scale constraint programming model of alternative splicing regulation. Theoretical Computer Science, 2004, Special issue: computational systems biology, 325 (1), pp.3-24. ⟨10.1016/j.tcs.2004.03.062⟩. ⟨inria-00000916⟩
159 Consultations
0 Téléchargements
