Limit theorems for the multilevel splitting algorithm in the simulation of rare events, Proceedings of the Winter Simulation Conference, 2005. ,
DOI : 10.1109/WSC.2005.1574309
Probability and Statistics II, 1986. ,
Feynman?Kac Formulae. Genealogical and Interacting Particle Systems with Applications . Probability and its Applications, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00426415
Interacting particle filtering with discrete observations, Sequential Monte Carlo Methods in Practice, pp.43-75, 2001. ,
The Monte Carlo method for filtering with discrete?time observations. Probability Theory and Related Fields, pp.346-368, 2001. ,
Branching and interacting particle interpretation of rare event probabilities, Stochastic Hybrid Systems : Theory and Safety Critical Applications ,
Branching and interacting particle systems approximations of Feynman?Kac formulae with applications to nonlinear filtering, Séminaire de Probabilités XXXIV, pp.1-145, 2000. ,
Stopped Random Walks. Limit Theorems and Applications, 1988. ,
Recursive Monte Carlo filters : Algorithms and theoretical analysis. The Annals of Statistics, pp.1983-2021, 2005. ,
A robustification approach to stability and to uniform particle approximation of nonlinear filters : the example of pseudo-mixing signals, Stochastic Processes and their Applications, pp.279-316, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00072157
Stability and uniform approximation of nonlinear filters using the Hilbert metric, and application to particle filters, The Annals of Applied Probability, vol.14, issue.1, pp.144-187, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00912081
A sequential particle algorithm that keeps the particle system alive, Proceedings of the 13th European Signal Processing Conference, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00001090
Discrete?Parameter Martingales, 1975. ,
Stabilité et Approximations Particulaires en Filtrage Non?Linéaire ? Application au Pistage, Thèse de Doctorat, 2000. ,
Stability and uniform particle approximation of nonlinear filters in case of non ergodic signal. Stochastic Analysis and Applications, pp.421-448, 2005. ,
On the asymptotic distribution of the sum of a random number of independent random variables, Acta Mathematica Academiae Scientiarum Hungaricae, vol.63, issue.64, pp.193-199, 1957. ,
DOI : 10.1007/BF02025242
Filtrage Non?Linéaire par Noyaux de Convolution ? ApplicationàApplication`Applicationà un Procédé de Dépollution Biologique, Thèse de Doctorat, ´ Ecole Nationale Supérieure Agronomique de Montpellier, 2004. ,
