The use of the Hilbert transform in ECG signal analysis, Computers in Biology and Medicine, vol.31, issue.5, pp.31-399, 2001. ,
DOI : 10.1016/S0010-4825(01)00009-9
Wavelet based analysis and characterization of the ECG signal, J. Med. Eng. Technol, vol.28, issue.2, pp.47-55, 2004. ,
Temporal abstraction and inductive logic programming for arrhythmia recognition from electrocardiograms, Artif. Intell. Med, vol.28, pp.231-263, 2003. ,
URL : https://hal.archives-ouvertes.fr/inserm-00134396
Electrocardiogram signal preprocessing for automatic detection of QRS boundaries, Med. Eng. Phys, vol.21, pp.37-44, 1999. ,
Ventricular beat detection in single channel electrocardiograms, Biomed. Eng. Online, vol.3, issue.1, 2004. ,
QRS wave detection, Med. Biol. Eng. Comput, vol.18, pp.125-132, 1980. ,
A comparison of the noise sensitivity of nine QRS detection algorithms, IEEE Trans. Biomed. Eng, vol.37, pp.85-98, 1990. ,
Multisensor fusion for atrial and ventricular activity detection in coronary care monitoring, IEEE Trans. Biomed. Eng, issue.10, pp.46-1186, 1999. ,
URL : https://hal.archives-ouvertes.fr/inserm-00134401
Detection algorithms in implantable cardioverter defibrillators, Proc. of the IEEE, pp.428-445, 1996. ,
Wavelet transform-based QRS complex detector, IEEE Trans. Biomed. Eng, vol.46, issue.7, pp.838-848, 1999. ,
The principles of software QRS detection, IEEE Eng. Med. Biol. Mag, vol.21, issue.1, pp.42-57, 2002. ,
Principles of multivariate analysisOxford Statistical Science Series, p.53, 1998. ,
MIT-BIH arrhythmia data base directory', Massachusetts Institute of Technology MOODYA noise stress test for arrhythmia detectors, Comput. Cardiol, vol.11, pp.381-384, 1984. ,
A QRS delineation algorithm with low sensitivity to noise and morphology changes, Proc. IEEE Comput. Cardiol, pp.347-350, 1981. ,
A real-time QRS detection algorithm, IEEE Trans. Biomed. Eng. BME, issue.3, pp.32-230, 1985. ,
Genetic design of optimum linear and nonlinear QRS detectors, IEEE Trans. Biomed. Eng, vol.42, issue.11, pp.1137-1141, 1995. ,
Intelligent patient monitoring and management systems: a review, IEEE Eng. Med. Biol .Mag, vol.12, issue.4, pp.23-33, 1993. ,
Some new applications of the wavelet transforms, 14th An. Int. Conf. IEEE-EMBS, pp.14-2592, 1992. ,
Towards an intelligent problem-solving environment for signal processing, Math. Comput. Simul, vol.36, pp.347-359, 1994. ,
Artificial neural networks for automatic ECG analysis, IEEE Trans. Signal Process, vol.46, issue.5, pp.1417-1425, 1998. ,
ECG signal conditioning by morphological filtering, Comput. Biol. Med, vol.32, pp.465-479, 2002. ,
A comparative study of depth EEG seizure signals: Proposition for a method based on a physiologically relevant parameter, Annal of Biom. Eng, vol.25, pp.1026-1039, 1997. ,
Classification of premature ventricular complexes using filter bank features, induction of decision trees and a fuzzy rule-based system, Med. Biol. Eng. Comput, vol.37, issue.5, pp.560-565, 1999. ,
The bootstrap and its application in signal processing, 1998. ,
