Scanning polyhedra with DO loops, 3rd ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, pp.39-50, 1991. ,
URL : https://hal.archives-ouvertes.fr/hal-00752774
Efficient code generation for automatic parallelization and optimization, Second International Symposium on Parallel and Distributed Computing, 2003. Proceedings., pp.23-30, 2003. ,
DOI : 10.1109/ISPDC.2003.1267639
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
Improving Data Locality by Chunking, CC'12 Intl. Conf. on Compiler Construction, pp.320-335, 2003. ,
DOI : 10.1007/3-540-36579-6_23
URL : https://hal.archives-ouvertes.fr/inria-00001055
Loop parallelization algorithms: From parallelism extraction to code generation, Parallel Computing, vol.24, issue.3-4, pp.421-444, 1998. ,
DOI : 10.1016/S0167-8191(98)00020-9
URL : https://hal.archives-ouvertes.fr/hal-00856896
Facilitating the search for compositions of program transformations, Proceedings of the 19th annual international conference on Supercomputing , ICS '05, pp.151-160, 2005. ,
DOI : 10.1145/1088149.1088169
URL : https://hal.archives-ouvertes.fr/hal-01257296
Mapping uniform loop nests onto distributed memory architectures, Parallel Computing, vol.20, issue.5, pp.679-710, 1994. ,
DOI : 10.1016/0167-8191(94)90001-9
URL : https://hal.archives-ouvertes.fr/hal-00857077
Dataflow analysis of array and scalar references, International Journal of Parallel Programming, vol.24, issue.4, pp.23-53, 1991. ,
DOI : 10.1007/BF01407931
Some efficient solutions to the affine scheduling problem. Part II. Multidimensional time, International Journal of Parallel Programming, vol.2, issue.4, pp.389-420, 1992. ,
DOI : 10.1007/BF01379404
A complete compiler approach to auto-parallelizing C programs for multi-DSP systems, IEEE Transactions on Parallel and Distributed Systems, vol.16, issue.3, pp.234-245, 2005. ,
DOI : 10.1109/TPDS.2005.26
A Case Study of Design Space Exploration for Embedded Multimedia Applications on SoCs, Seventeenth IEEE International Workshop on Rapid System Prototyping (RSP'06), 2005. ,
DOI : 10.1109/RSP.2006.1
Programmable stream processors, Computer, vol.36, issue.8, pp.54-62, 2003. ,
DOI : 10.1109/MC.2003.1220582
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.7599
A framework for unifying reordering transformations, 1993. ,
Code generation for multiple mappings, Proceedings Frontiers '95. The Fifth Symposium on the Frontiers of Massively Parallel Computation, 1995. ,
DOI : 10.1109/FMPC.1995.380437
The Structure of Computers and Computations, 1978. ,
A note on Chernikova's algorithm, 1992. ,
Loop parallelization in the polytope model, Int. Conf. on Concurrency Theory, pp.398-416, 1993. ,
DOI : 10.1007/3-540-57208-2_28
A singular loop transformation framework based on non-singular matrices, International Journal of Parallel Programming, vol.16, issue.4, pp.183-205, 1994. ,
DOI : 10.1007/BF02577874
Maximizing parallelism and minimizing synchronization with affine transforms, Proceedings of the 24th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '97, pp.201-214, 1997. ,
DOI : 10.1145/263699.263719
Optimizing Cache Access: A Tool for Source-to-Source Transformations and Real-Life Compiler Tests, Euro-Par 2004 Parallel Processing, 10th International Euro-Par Conference, pp.72-81, 2004. ,
DOI : 10.1007/978-3-540-27866-5_10
The Omega test: a fast and practical integer programming algorithm for dependence analysis, Proceedings of the 1991 ACM/IEEE conference on Supercomputing , Supercomputing '91, pp.4-13, 1991. ,
DOI : 10.1145/125826.125848
Uniform techniques for loop optimization, Proceedings of the 5th international conference on Supercomputing , ICS '91, pp.341-352, 1991. ,
DOI : 10.1145/109025.109108
Generation of efficient nested loops from polyhedra, International Journal of Parallel Programming, vol.28, issue.5, pp.469-498, 2000. ,
DOI : 10.1023/A:1007554627716
Beyond unimodular transformations, The Journal of Supercomputing, vol.3, issue.5, pp.365-389, 1995. ,
DOI : 10.1007/BF01206273
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.41.5188
Theory of linear and integer programming, 1986. ,
High performance compilers for parallel computing, 1995. ,
Automating non-unimodular loop transformations for massive parallelism, Parallel Computing, vol.20, issue.5, pp.711-728, 1994. ,
DOI : 10.1016/0167-8191(94)90002-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.26.7037
