Audio asymmetric watermarking technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
Teddy Furon
This paper presents the application of the promising public key watermarking method1 to the audio domain. Its de- tection process does not need the original content nor the secret key used in the embedding process. It is the trans- lation, in the watermarking domain, of a public key pair cryptosystem [1]. We start to build the detector with some basic assumptions. This leads to a hypothesis test based on probability likelihood. But real audio signals do not satisfy the assumption of a Gaussian probability density function. Moreover, the use of an advanced human perception model to hide the watermark makes the detection issue a tough problem. Our works result in a new detection process o er- ing a good test's power for a low probability of false alarm.
Icassp2000.pdf (320.23 Ko) Télécharger le fichier
inria-00001126 , version 1 (20-02-2006)
  • HAL Id : inria-00001126 , version 1
Teddy Furon, Nicolas Moreau, Pierre Duhamel. Audio asymmetric watermarking technique. Int. Conf. on Audio, Speech and Signal Processing, IEEE, Jun 2000, Istanbul, Turkey. ⟨inria-00001126⟩
18 Consultations
35 Téléchargements
