Résumé : Many networked applications use end-to-end congestion control protocols to avoid the occurrence of congestion collapse phenomena. However, such transport protocols may suffer from link underutilization when there are wireless links along the path: the inability to distinguish wireless losses from congestion losses often results in unnecessary throughput decreases. Since networks are becoming increasingly heterogeneous, consisting of a mix of wired and wireless links, it is important to have some means of correctly identifying the cause of a packet loss, so as to adapt the response of the transport protocol. In this paper, we present an end-to-end solution to this problem and propose a novel method for Wireless Loss Estimation in IP DiffServ networks (WLED). WLED aims at enhancing the performance of equation-based rate control protocols for multimedia applications, by means of directly estimating the wireless and congestion loss rates. We discuss the integration of WLED with a recent, equation-based rate control protocol and we evaluate WLED's performance through simulation. Our results illustrate a new benefit of using DiffServ-like mechanisms for multimedia streaming in wireless networks. \\ Les applications multimédia doivent en général utiliser des protocoles de contrôle de congestion de bout en bout afin d'éviter l'écroulement du réseau par congestion. Cependant, lorsque de tels protocoles sont employés il y a une sous-utilisation de la bande passante lorsqu'il y a des liaisons sans-fils le long du chemin : l'incapacité de distinguer des pertes dues au sans-fil de celles dues à la congestion entraîne une diminution inutile du taux de transmission. Les réseaux deviennent de plus en plus hétérogènes et utilisent des liaisons filaires et sans-fil. Il est donc important de disposer de moyens permettant d'identifier correctement la cause de la perte des paquets afin d'adapter le mécanisme de contrôle de congestion du protocole de transport. Dans cet article, nous présentons une solution de bout en bout à ce problème et proposons une méthode d'estimation de pertes dues au sans-fil dans les réseaux IP DiffServ (WLED: Wireless Loss Estimation in IP Diffserv networks). WLED augmente la performance des protocoles de contrôle de débit basés sur des modèles mathématiques pour des applications multimédia, par estimation directe des taux de pertes dues au sans-fil et à la congestion. Nous étudions l'intégration de WLED dans un protocole récent de contrôle de débit et nous évaluons la performance de WLED par simulation. Nos résultats montrent un nouvel avantage d'utiliser les mécanismes DiffServ pour la transmission multimédia dans les réseaux ans-fil.
