HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Role-Based Access Control for XML Enabled Multi-Protocol Management Gateways
Vincent Cridlig 1 Radu State 1 Olivier Festor 1
1 MADYNES - Management of dynamic networks and services
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : While security is often supported in standard management frameworks, security is of major importance in the management plane. In this paper we address the provisioning of a security ``continuum'' for management frameworks based on multi-protocol gateways. We provide an in depth security extension of such a gateway using the Role Based Access Control paradigm and show how to integrate our approach within a broader XML-based management framework. Two case studies are investigated: while the first one proposes to map an XML-based RBAC policy to SNMP access control model, the second one maps the same policy to CLI security levels. The target objective is to provide consistent access control policies not only locally on each device whatever be the network management framework but also globally through the managed domain.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00001222
Contributor : Vincent Cridlig Connect in order to contact the contributor
Submitted on : Monday, April 10, 2006 - 10:27:04 AM
Last modification on : Thursday, April 7, 2022 - 3:08:59 AM
Identifiers
  • HAL Id : inria-00001222, version 1
Collections
Citation
Vincent Cridlig, Radu State, Olivier Festor. Role-Based Access Control for XML Enabled Multi-Protocol Management Gateways. IEEE Transactions on Network and Service Management, IEEE, 2006, Adapting to Dynamic Environments, 3 (1). ⟨inria-00001222⟩
Share
Metrics
Record views
53
