On the decomposition of excursions measures of processes whose generators have diffusion coefficients discontinuous at one point - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Markov Processes And Related Fields Année : 2002
The coefficients in the decomposition of the excursions measure as convex combination of excursions measures of reflected processes are computed in order to characterize the discontinuity at one point of the diffusion coefficient. In some sense, this result extends to general diffusions a similar one for the skew Brownian motion, and we advocate it may be used in Monte Carlo methods for discontinuous media.
lejay-decomposition-excursion-measure.pdf (225.58 Ko) Télécharger le fichier
inria-00001230 , version 1 (10-04-2006)
  • HAL Id : inria-00001230 , version 1
Antoine Lejay. On the decomposition of excursions measures of processes whose generators have diffusion coefficients discontinuous at one point. Markov Processes And Related Fields, 2002, 8 (1), pp.117-126. ⟨inria-00001230⟩
146 Consultations
162 Téléchargements
