Structural joins: a primitive for efficient XML query pattern matching, Proceedings 18th International Conference on Data Engineering, 2002. ,
DOI : 10.1109/ICDE.2002.994704
Tree pattern query minimization, The VLDB Journal The International Journal on Very Large Data Bases, vol.11, issue.4, 2002. ,
DOI : 10.1007/s00778-002-0076-7
XML Access Modules: Towards Physical Data Independence in XML Databases, 2005. ,
ULoad: Choosing the Right Store for your XML Application (demo), VLDB, 2005. ,
A Framework for Using Materialized XPath Views in XML Query Processing, VLDB, 2004. ,
DOI : 10.1016/B978-012088469-8.50009-7
Interaction between path and type constraints, ACM Trans. Comput. Log, vol.4, issue.4, 2003. ,
DOI : 10.1145/303976.303982
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.11.9123
XCache, Proceedings of the 2002 ACM SIGMOD international conference on Management of data , SIGMOD '02, 2002. ,
DOI : 10.1145/564691.564771
From Tree Patterns to Generalized Tree Patterns, VLDB, 2003. ,
DOI : 10.1016/B978-012722442-8/50029-X
Rewriting nested XML queries using nested XML views, SIGMOD, 2006. ,
The NEXT logical framework for XQuery, VLDB, 2004. ,
Containment and integrity constraints for XPath, KRDB Workshop, 2001. ,
MARS, VLDB, 2003. ,
DOI : 10.1016/B978-012722442-8/50026-4
Containment of Nested XML Queries, VLDB, 2004. ,
DOI : 10.1016/B978-012088469-8.50015-2
Query containment for conjunctive queries with reg. expressions, PODS, 1998. ,
Dataguides: Enabling query formulation and optimization in semistructured databases, VLDB, 1997. ,
The complexity of XPath query evaluation, Proceedings of the twenty-second ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '03, 2003. ,
DOI : 10.1145/773153.773171
Answering queries using views, PODS, 1995. ,
The XML web, Proceedings of the twelfth international conference on World Wide Web , WWW '03, 2003. ,
DOI : 10.1145/775152.775223
Containment and equivalence for an XPath fragment, PODS, 2002. ,
XPath containment in the presence of disjunction, DTDs, and variables, ICDT, 2003. ,
ORDPATHs: Insert-friendly XML node labels, SIGMOD, 2004. ,
Query rewriting for semistructured data, SIGMOD, 1999. ,
Tree logical classes for efficient evaluation of XQuery, Proceedings of the 2004 ACM SIGMOD international conference on Management of data , SIGMOD '04, 2004. ,
DOI : 10.1145/1007568.1007579
Recursive XML schemas, recursive XML queries, and relational storage: XML-to-SQL query translation, ICDE, 2004. ,
Storing and querying ordered XML using a relational database system, Proceedings of the 2002 ACM SIGMOD international conference on Management of data , SIGMOD '02, 2002. ,
DOI : 10.1145/564691.564715
Containment for XPath Fragments under DTD Constraints, ICDT, 2003. ,
DOI : 10.1007/3-540-36285-1_20
Rewriting XPath queries using materialized views, VLDB, 2005. ,
