Peer-to-Peer and Fault-Tolerance: Towards Deployment Based Technical Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
For effective components, non-functional aspects must be added to the application functional code. Likewise enterprise middleware and component platforms, in the context of Grids, services must be deployed at execution in the component containers in order to implement those aspects. This paper proposes an architecture for defining, configuring, and deploying such Technical Services in a Grid platform.
PeerToPeerAndFaultToleranceTowardsDeploymentBasedTechnicalServices.pdf (146.44 Ko) Télécharger le fichier
inria-00001238 , version 1 (11-04-2006)
  • HAL Id : inria-00001238 , version 1
Denis Caromel, Christian Delbe, Alexandre Di Costanzo. Peer-to-Peer and Fault-Tolerance: Towards Deployment Based Technical Services. Second CoreGRID Workshop on Grid and Peer to Peer Systems Architecture, Jan 2006, Paris, France. ⟨inria-00001238⟩
146 Consultations
242 Téléchargements
