Advances in computational stereo, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.8, pp.993-1008, 2003. ,
DOI : 10.1109/TPAMI.2003.1217603
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.6.411
A taxonomy and evaluation of dense two-frame stereo correspondence algorithms, Proceedings IEEE Workshop on Stereo and Multi-Baseline Vision (SMBV 2001), pp.7-42, 2002. ,
DOI : 10.1109/SMBV.2001.988771
Discrete signal matching using coarse-to-fine wavelet basis functions, Pattern Recognition, vol.36, issue.1, pp.171-192, 2003. ,
DOI : 10.1016/S0031-3203(02)00024-9
Uncalibrated stereo matching using DWT, Proc. Int. Conf. Pattern Recognition, pp.114-118, 2000. ,
Stereo matching algorithm based on modified wavelet decomposition process, Pattern Recognition, vol.30, issue.6, pp.929-952, 1997. ,
DOI : 10.1016/S0031-3203(96)00125-2
WAVELET-CONSTRAINED IMAGE RESTORATION, International Journal of Wavelets, Multiresolution and Information Processing, vol.02, issue.04, pp.371-389, 2004. ,
DOI : 10.1142/S0219691304000688
URL : https://hal.archives-ouvertes.fr/hal-00017834
Image Restoration Subject to a Total Variation Constraint, IEEE Transactions on Image Processing, vol.13, issue.9, pp.1213-1222, 2004. ,
DOI : 10.1109/TIP.2004.832922
URL : https://hal.archives-ouvertes.fr/hal-00017934
Multiple basis wavelet denoising using Besov projections, Proc. IEEE Int. Conf. Image Proc, pp.595-599, 1999. ,
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.185.1651
Time-invariant orthonormal wavelet representations, IEEE Transactions on Signal Processing, vol.44, issue.8, pp.1964-1970, 1996. ,
DOI : 10.1109/78.533717
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.45.2234
Variational Optic Flow Computation: From Continuous Models to Algorithms, Int. Workshop on Computer Vision and Image Analysis, 2003. ,
Bottom Center) 2-pass DP [17]. (Bottom Right) Patch-Based [18]. ity map estimation respecting image discontinuities: A PDE and scale-space based approach, Journal of Visual Communication and Image Representation, vol.16, issue.13, pp.3-21, 2002. ,
A block-iterative surrogate constraint splitting method for quadratic signal recovery, IEEE Transactions on Signal Processing, vol.51, issue.7, pp.1771-1782, 1997. ,
DOI : 10.1109/TSP.2003.812846
A theory for multiresolution signal decomposition: the wavelet representation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.7, pp.674-693, 1989. ,
DOI : 10.1109/34.192463
An Investigation of Smoothness Constraints for the Estimation of Displacement Vector Fields from Image Sequences, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.8, issue.5, pp.565-593, 1986. ,
DOI : 10.1109/TPAMI.1986.4767833
A layered stereo algorithm using image segmentation and global visibility constraints, Int. Conf. on Image Proc, pp.2997-3000, 2004. ,
A dense stereo matching using two-pass dynamic programming with generalized ground control points, Computer Vision and Pattern Recognition, vol.2, pp.1075-1082, 2005. ,
A symmetric patchbased correspondence model for occlusion handling, Int. Conf on Computer Vision, pp.1316-1322, 2005. ,
