Flights Alternative Routes Generator by Genetic Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper present a new Air Traffic routes generator based on Genetic Algorithms. Due to the traffic growth, direct (and near direct) routes are more and more congested and there is a real need for spreading the traffic on new alternative routes. Those routes have to be different from several operational criteria and must not generate too much extra-distance compared with the direct route. To reach this goal, a GA has been implemented with an efficient sharing which automatically allows the emergence of different alternative routes. This algorithm has been tried on the French airspace and gives realistic operational results.
cec2000.pdf (237.74 Ko) Télécharger le fichier
inria-00001274 , version 1 (04-05-2006)
Sofiane Oussedik, Daniel Delahaye, Marc Schoenauer. Flights Alternative Routes Generator by Genetic Algorithms. CEC 2000, Jul 2000, San Diego, CA,USA, pp.896-901, ⟨10.1109/CEC.2000.870735⟩. ⟨inria-00001274⟩
134 Consultations
179 Téléchargements
