Identifiabilty of systems described by convolution equations, Automatica, vol.41, issue.3, pp.505-512, 2005. ,
DOI : 10.1016/j.automatica.2004.11.013
Identifiability and identification of linear systems with delays Advances in Time- Delay Systems, Lect. Notes Comput ,
Active vibration control using on-line algebraic identification of harmonic vibrations, Proc. Amer. Control Conf, 2005. ,
Analyse non standard du bruit, Comptes Rendus Mathematique, vol.342, issue.10, pp.797-802, 2006. ,
DOI : 10.1016/j.crma.2006.02.037
URL : https://hal.archives-ouvertes.fr/inria-00001134
Robust residual generation for linear fault diagnosis: an algebraic setting with examples, International Journal of Control, vol.34, issue.14, pp.1223-1242, 2004. ,
DOI : 10.1080/002071704200024374
Closed-Loop Fault-Tolerant Control for Uncertain Nonlinear Systems, Lect. Notes Control Informat. Sci, vol.322, pp.217-233, 2005. ,
DOI : 10.1007/11529798_14
URL : https://hal.archives-ouvertes.fr/inria-00111208
An extension of predictive control, PID regulators and Smith predictors to some linear delay systems, International Journal of Control, vol.6, issue.10, pp.728-743, 2002. ,
DOI : 10.1007/978-1-4612-1118-1
Questioning some paradigms of signal processing via concrete examples, Algebraic Methods in Flatness, Signal Processing and State Estimation, Editiorial Lagares, pp.1-21, 2003. ,
An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
URL : http://www.numdam.org/article/COCV_2003__9__151_0.pdf
Sira-Ramírez, Control via state estimations of some nonlinear systems, Proc. Symp. Nonlinear Control Systems, issue.avalable, 2004. ,
Online identification of continuous-time systems with unknown time delay, IEEE Transactions on Automatic Control, vol.50, issue.9, pp.1418-1422, 2005. ,
DOI : 10.1109/TAC.2005.854640
Time-delay systems: an overview of some recent advances and open problems, Automatica, vol.39, issue.10, pp.1667-1694, 2003. ,
DOI : 10.1016/S0005-1098(03)00167-5
Delay system identification applied to the longitudinal flight of an aircraft through a vertical gust, Théorie des distributions Proc. 14 th Medit. Conf. Control Automat, 1966. ,
