Abstract : is a software which allows to define matches between primitives belonging to frames of a video sequence. In particular, it allows the definition of a video sub-sequence, the manual or automatic definition of the primitives, the manual or automatic matching of these primitives.This document is made up of the analysis of , according to the OMT (Object Modelling Technique) method. It aims at understanding and modelling the application under three main features: the object model, the functional model and the dynamic model.The conception of the objects and their implementation as well are based on these specifications.
