Defined . Same as Proof . . . . Qed . but the proof is then declared transparent (see 5.2.5), which means it can be unfolded in conversion tactics ,
Save ident Same as Lemma ident: type. . . Save. This is intended to be used in the interactive mode. Conversely to named lemmas, anonymous goals cannot be nested ,
= Coq < | f_and : formula -> formula -> formula Coq < | f_or : formula -> formula -> formula Coq < | f_not : formula -> formula Coq < | f_true : formula Coq < | f_const : Prop -> formula (* constructor for constants *) ,
index -> formula. (* constructor for variables *) ,
Quote interp_f, subgoal ============================ (interp_f (Node_vm C<->C (Empty_vm Prop) (Empty_vm Prop)) (f_and (f_const A) (f_and (f_or (f_const A) f_true) (f_and (f_not (f_const B)) (f_atom End_idx))))) ,
a solver of quantifier-free problems in Presburger Arithmetic 233 ,
233 Arithmetical goals recognized by, p.234 ,
235 Overview of the tactic, OMEGA decision procedure, vol.235, p.235 ,
237 Syntax of annotated programs, p.238 ,
243 Global variables, p.244 ,
251 Preview within Coq toplevel, 252 Generating real Ocaml files 252 Generating real Haskell files, p.252 ,
CC+ : an extension of the Calculus of Constructions with fixpoints, Proceedings of the 1992 Workshop on Types for Proofs and Programs, pp.21-34, 1992. ,
Extension du Calcul des Constructions par Points fixes, 1992. ,
Compiling pattern matching, Conference Functional Programming and Computer Architecture, 1985. ,
DOI : 10.1007/3-540-15975-4_48
Lambda Calculi with Types, Handbook of Logic in Computer Science, 1991. ,
The Lambda Calculus its Syntax and Semantics, 1981. ,
Proofs as programs, ACM Transactions on Programming Languages and Systems, vol.7, issue.1, 1985. ,
DOI : 10.1145/2363.2528
Foundations of Constructive Mathematics, Metamathematical Studies, 1985. ,
A decision procedure revisited: notes on direct logic, linear logic and its implementation, Theoretical Computer Science, vol.95, issue.1, pp.115-142, 1992. ,
DOI : 10.1016/0304-3975(92)90069-R
Foundations of Constructive Analysis, 1967. ,
Certification d'un compilateur ML en Coq, 1992. ,
Réflexions sur les quotients. thèse d'université, 1997. ,
Using reflection to build efficient and certified decision procedures, TACS'97, 1997. ,
DOI : 10.1007/BFb0014565
A computational logic, 1979. ,
Implementing Mathematics with the Nuprl Proof Development System, 1986. ,
Une Théorie des Constructions, 1985. ,
An Analysis of Girard's Paradox, Symposium on Logic in Computer Science, 1986. ,
Metamathematical Investigations of a Calculus of Constructions, Logic and Computer Science, 1990. ,
Pattern Matching with Dependent Types ,
Infinite Objects in Type Theory, Barendregt and Nipkow ,
Constructions : A Higher Order Proof System for Mechanizing Mathematics, EUROCAL'85, 1985. ,
The Calculus of Constructions, Information and Computation, vol.76, issue.23, 1988. ,
Inductively defined types, Proceedings of Colog'88, 1990. ,
Explicitation de preuves par récurrence implicite, 1994. ,
Lambda-Calculus Notation with Nameless Dummies, a Tool for Automatic Formula Manipulation, with Application to the Church-Rosser Theorem, Indag. Math, vol.34, 1972. ,
A Survey of the Project Automath, to H.B. Curry : Essays on Combinatory Logic, Lambda Calculus and Formalism, 1980. ,
DOI : 10.1016/S0049-237X(08)70203-9
Camlp4 version 1.07.2, Camlp4 distribution, 1998. ,
Information Retrieval in a Coq Proof Library Using Type Isomorphisms, Proceedings of TYPES'99, 1999. ,
DOI : 10.1017/S095679680000006X
A Tactic Language for the System Coq Reunion Island, Proceedings of Logic for Programming and Automated Reasoning (LPAR), pp.85-95, 2000. ,
Field: une procédure de décision pour les nombres réels en Coq, 2001. ,
Isomorphisms of Types: from -calculus to information retrieval and language design, Progress in Theoretical Computer Science. Birkhauser, 1995. ,
Naming and Scoping in a Mathematical Vernacular, Research Report, vol.1283, 1990. ,
URL : https://hal.archives-ouvertes.fr/inria-00075276
A second-order pattern matching algorithm for the cube of typed ??-calculi ,
DOI : 10.1007/3-540-54345-7_58
URL : https://hal.archives-ouvertes.fr/inria-00074975
Démonstration automatique dans le Calcul des Constructions, 1991. ,
Indécidabilité du Filtrage du Troisième Ordre dans les Calculs avec Types Dépendants ou Constructeurs de Types Compte Rendu de l'Académie des Sciences, I, pp.312951-956, 1991. ,
The undecidability of pattern matching in calculi where primitive recursive functions are representable, Theoretical Computer Science, vol.107, issue.2, 1992. ,
DOI : 10.1016/0304-3975(93)90175-S
A Complete Proof Synthesis Method for the Cube of Type Systems, Journal of Logic and Computation, vol.3, issue.3, pp.287-315, 1993. ,
DOI : 10.1093/logcom/3.3.287
Third order matching is decidable, [1992] Proceedings of the Seventh Annual IEEE Symposium on Logic in Computer Science, pp.135-155, 1994. ,
DOI : 10.1109/LICS.1992.185514
Lambda-calculus, Combinators and the Comprehension Schema, Proceedings of the second international conference on typed lambda calculus and applications, 1995. ,
The Coq Proof Assistant User's Guide Version 5, 1993. ,
Inductive sets and families in Martin-Löf's Type Theory and their set-theoretic semantics : An inversion principle for Martin-Löf's type theory, Logical Frameworks, pp.59-79, 1991. ,
Contraction-free sequent calculi for intuitionistic logic, The Journal of Symbolic Logic, vol.475, issue.03, 1992. ,
DOI : 10.1007/3-540-54487-9_58
Une procédure de décision pour le Calcul des Prédicats Direct. Etude et implémentation dans le système Coq, 1994. ,
A decision procedure for Direct Predicate Calculus, 1995. ,
Preuve de programmes impératifs en théorie des types, Thèse de doctorat, 1999. ,
Formal Proof of a Program: Find. Submitted to Science of Computer Programming, 2000. ,
Verification of non-functional programs using interpretations in type theory, Journal of functional Programming, vol.13, issue.4, 2000. ,
DOI : 10.1017/S095679680200446X
Certification of sorting algorithms in the system Coq, Theorem Proving in Higher Order Logics: Emerging Trends, 1999. ,
Implantation des algorithmes de Floyd et de Dijkstra dans le Calcul des Constructions, 1990. ,
The Calculus of Constructions. Documentation and user's guide, Version 4.10, 1989. ,
URL : https://hal.archives-ouvertes.fr/inria-00070056
Fourier's method to solve linear inequations/equations systems, 1890. ,
Codifying guarded definitions with recursive schemes In Types'94 : Types for Proofs and Programs Extended version in LIP research report, LNCS, vol.996, pp.95-102, 1994. ,
An application of co-inductive types in Coq: Verification of the alternating bit protocol, Workshop on Types for Proofs and Programs, number 1158 in LNCS, pp.135-152, 1995. ,
DOI : 10.1007/3-540-61780-9_67
A tutorial on recursive types in coq, 1998. ,
Une extension de l'interprétation de Gödel à l'analyse, et son application à l'élimination des coupures dans l'analyse et la théorie des types, Proceedings of the 2nd Scandinavian Logic Symposium. North-Holland, 1970. ,
Interprétation fonctionnelle et élimination des coupures de l'arithmétique d'ordre supérieur, 1972. ,
Proofs and Types. Cambridge Tracts in Theoretical Computer Science 7, 1989. ,
Metatheory and reflection in theorem proving: A survey and critique, 1995. ,
Ecriture d'une tactique arithmétique pour le système Coq, 1994. ,
The formulae-as-types notion of constructions, to H.B. Curry : Essays on Combinatory Logic, Lambda Calculus and Formalism, 1980. ,
Induction principles formalized in the calculus of constructions, Programming of Future Generation Computers Also in Proceedings of TAPSOFT87, pp.276-286, 1987. ,
DOI : 10.1007/3-540-17660-8_62
The Constructive Engine A perspective in Theoretical Computer Science. Commemorative Volume for Gift Siromoney, 1989. ,
The Gallina specification language: A case study, Proceedings of 12th FST/TCS Conference, pp.229-240, 1992. ,
DOI : 10.1007/3-540-56287-7_108
Abstract, Journal of Functional Programming, vol.34, issue.03, pp.371-394, 1994. ,
DOI : 10.1017/S0956796800001106
Call by need computations in non-ambigous linear term rewriting systems, Computational Logic, Essays in Honor of Alan Robinson, 1979. ,
A decidable fragment of predicate calculus, Theoretical Computer Science, vol.32, issue.3, pp.297-307, 1984. ,
DOI : 10.1016/0304-3975(84)90047-1
Introduction to Metamathematics, Bibliotheca Mathematica. North-Holland, 1952. ,
Lambda-calcul types et modèles. Etudes et recherche en informatique, 1990. ,
DOI : 10.1051/ita/1991250100671
URL : http://archive.numdam.org/article/ITA_1991__25_1_67_0.pdf
Comparison of priority rules in pattern matching and term rewriting, Journal of Symbolic Computation, vol.11, issue.4, pp.321-347, 1991. ,
DOI : 10.1016/S0747-7171(08)80109-5
URL : https://hal.archives-ouvertes.fr/inria-00075676
Programming with streams in Coq a case study: The Sieve of Eratosthenes, Types for Proofs and Programs, Types' 93, 1994. ,
DOI : 10.1007/3-540-58085-9_77
The ZINC experiment: an economical implementation of the ML language, 1990. ,
URL : https://hal.archives-ouvertes.fr/inria-00070049
Compiling Pattern Matching by Term Decomposition, Conference Lisp and Functional Programming, 1990. ,
DOI : 10.1006/jsco.1993.1001
URL : http://doi.org/10.1006/jsco.1993.1001
A user's friendly syntax to define recursive functions as typed ??-terms, Types for Proofs and Programs, TYPES'94, 1994. ,
DOI : 10.1007/3-540-60579-7_5
Automatizing termination proofs of recursively defined functions, Theoretical Computer Science, vol.135, issue.2 ,
DOI : 10.1016/0304-3975(94)00021-2
URL : https://hal.archives-ouvertes.fr/hal-00528475
Two Techniques for Compiling Lazy Pattern Matching, 1994. ,
URL : https://hal.archives-ouvertes.fr/inria-00074292
Démonstration automatique dans la logique propositionnelle intuitionniste. Master's thesis, DEA d'Informatique Fondamentale, 1994. ,
Un calcul de substitutions pour la représentation de preuves partielles en théorie de types, Thèse de doctorat, 1997. ,
Terminating general recursion, BIT, vol.24, issue.3, 1988. ,
DOI : 10.1007/BF01941137
Programming in Martin-Löf's Type Theory. International Series of Monographs on Computer Science, 1990. ,
Intuitionistic Type Theory, 1984. ,
Developing certified programs in the system Coq the program tactic, 1993. ,
DOI : 10.1007/3-540-58085-9_81
Synthèse de preuves de programmes dans le Calcul des Constructions Inductives, 1995. ,
Synthesizing proofs from programs in the Calculus of Inductive Constructions, Mathematics of Program Construction'95, 1995. ,
DOI : 10.1007/3-540-60117-1_20
Recursive programming with proofs, Theoretical Computer Science, vol.94, issue.2, pp.335-356, 1992. ,
DOI : 10.1016/0304-3975(92)90042-E
ProPre : A Programming language with proofs, Logic Programming and automated reasoning, number 624 in LNCS, 1992. ,
Extracting ??'s programs from proofs in the calculus of constructions, Proceedings of the 16th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '89 ,
DOI : 10.1145/75277.75285
Extraction de programmes dans le Calcul des Constructions, 1989. ,
URL : https://hal.archives-ouvertes.fr/tel-00431825
Inductive definitions in the system Coq rules and properties, Proceedings of the conference Typed Lambda Calculi and Applications, number 664 in LNCS, 1993. ,
DOI : 10.1007/BFb0037116
Le système Coq. Thèse d'habilitation, ENS Lyon, 1997. ,
Synthesis of ML programs in the system Coq, Journal of Symbolic Computation, vol.15, issue.5-6, pp.607-640, 1993. ,
DOI : 10.1016/S0747-7171(06)80007-6
Programming with broadcasts, Proceedings of CONCUR'93, 1993. ,
DOI : 10.1007/3-540-57208-2_13
Développement de l'Algorithme d'Unification dans le Calcul des Constructions, 1992. ,
Axiomatization of a lambda-calculus with explicit-substitutions in the Coq System, 1994. ,
Résolution d'équations dans le système t de gödel. Master's thesis, DEA d'Informatique Fondamentale, 1994. ,
Traduction de TYPOL en COQ. Application à Mini ML. Master's thesis, IARFA, 1992. ,
Real theorem provers deserve real user-interfaces, Research Report, vol.1684, 1992. ,
Constructivism in Mathematics, an introduction, Studies in Logic and the foundations of Mathematics, volumes 121 and 123, 1988. ,
Efficient compilation of pattern matching The Implementation of Functional Programming Languages, 1987. ,
Index of Error Messages Unité de recherche INRIA Rocquencourt Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche INRIA Lorraine : LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38330 Montbonnot-St, Une théorie des constructions inductives Thèse de doctorat, pp.93-06902, 1994. ,
