HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
BLSURF - Mesh Generator for Composite Parametric Surfaces - User's Manual
Abstract : This technical report describes BLSURF, an automatic surface mesh generator. This software creates the mesh of a composite parametric surface while conforming to a prescribed size map. To this end, analytical functions defining the surface, as well as their first and possibly second derivatives, must be externally provided (for instance by a CAD system). Also, each patch must be described by giving its 2D parametric domain. The method used is based on an incremental Delaunay approach adapted to a Riemannian metric.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00069937
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, May 19, 2006 - 6:38:02 PM
Last modification on : Friday, January 21, 2022 - 3:16:36 AM
Long-term archiving on: : Saturday, April 3, 2010 - 10:38:08 PM
Identifiers
  • HAL Id : inria-00069937, version 1
Citation
Patrick Laug, Houman Borouchaki. BLSURF - Mesh Generator for Composite Parametric Surfaces - User's Manual. [Research Report] RT-0235, INRIA. 1999, pp.48. ⟨inria-00069937⟩
Share
Metrics
Record views
388
Files downloads
576
