Interactive Virtual Relighting and Remodeling of Real Scenes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
Lighting design is tedious due to the required physical manipulation of real light sources and objects. As an alternative, we present an interactive system to virtually modify the lighting and geometry of scenes with both real and synthetic objects, including mixed real/virtual lighting and shadows. In our method real scene geometry is first approximatively reconstructed from photographs. Additional images are taken with a real light in different positions from the same viewpoint to estimate reflectance. A filtering process is used to compensate for modeling errors, and per image reflectances are averaged to generate an approximate reflectance image for the given viewpoint, removing shadows in the process. This estimate is used to initialis- e a global illumination hierarchical radiosity system, representing real-world secondary illumination; the system is optimized for interactive updates. Direct illumination from lights is calculated separately using ray-casting and a table for efficient reuse where appropriate. Our system allows interactive modification of light emission and object positions, all with mixed real/virtual illumination effects. Real objects can also be virtually removed using texture-filling algorithms for reflectance estimation.
RT-0230.pdf (336.91 Ko) Télécharger le fichier
inria-00069942 , version 1 (19-05-2006)
  • HAL Id : inria-00069942 , version 1
Céline Loscos, Marie-Claude Frasson, George Drettakis, Bruce Walter, Xavier Granier, et al.. Interactive Virtual Relighting and Remodeling of Real Scenes. [Research Report] RT-0230, INRIA. 1999, pp.16. ⟨inria-00069942⟩
249 Consultations
686 Téléchargements
