Odyssée User's Guide Version 1.7 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 1998
Odyssée is an automatic differentiation processor for fortran code which implements both the forward and reverse mode of automatic differentiation. This document presents the functionalities of Odyssée through an illustrative example. It presents the basic concepts and objects of Odyssée, and completely describes the command language of Odyssée and its graphical user interface.
RT-0224.pdf (927.97 Ko) Télécharger le fichier
inria-00069947 , version 1 (19-05-2006)
  • HAL Id : inria-00069947 , version 1
Christèle Faure, Yves Papegay. Odyssée User's Guide Version 1.7. [Technical Report] RT-0224, INRIA. 1998, pp.81. ⟨inria-00069947⟩
122 Consultations
402 Téléchargements
