Applicability of the session and the presentation layers for the support of high speed applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
This report contains a detailed assessment of the session and presentation services and protocols in order to study their suitability to support high speed applications. We thus concentrate on the performance aspects of these standard protocols. The evaluation will be focused on the following topics : the assessment of the session layer, the suitability of some Interface Description Languages, data transparency and transfer syntaxes, the presentation protocol. A special interest is given to the description and evaluation of a light weight transfer syntax called FTLWS (Flat Tree Light Weight Syntax) proposed as an alternative to the ASN.1 Basic Encoding Rules.
Autre [cs.OH]
RT-0144.pdf (415.64 Ko) Télécharger le fichier
inria-00070024 , version 1 (19-05-2006)
  • HAL Id : inria-00070024 , version 1
Walid Dabbous, Christian Huitema, Leon Vidaller Siso, Joaquin Seoane, Julio Berrocal. Applicability of the session and the presentation layers for the support of high speed applications. [Research Report] RT-0144, INRIA. 1992, pp.60. ⟨inria-00070024⟩
109 Consultations
361 Téléchargements
