Abstract : We present a procedure for checking sufficient completeness for conditional and constrained term rewriting systems with axioms for constructors which may be constrained (by e.g. equalities, disequalities, ordering, membership...). Such axioms allow to specify complex data structures like e.g. sets, sorted lists or powerlists. Our method is integrated in a framework for inductive theorem proving based on tree grammars with constraints, a formalism which permits an exact representation of languages of ground constructor terms in normal form. The procedure is sound and complete. It has been successfully applied, yielding very natural proofs and, in case of negative answer, a counter example suggesting how to complete the specification. Moreover, it is a decision procedure when the TRS is unconditional but constrained, for a large class of constrained constructor axioms.
