Optimal release policy for prophylactic biological control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this paper, we study the prophylactic biological control strategy for greenhouse crops protection. The method consists in the preventive installation of natural enemies to fight against an invading pest, using discrete augmentative (inondative) releases of the natural enemies. We consider a simple non negative prey (pest) - predator (natural enemy) model in ordinary differential equations together with discrete augmentation of the predator population at constant frequency. Assuming we have a fixed budget to spend in natural enemies releases per time unit, we show the stability and efficiency of the prophylactic biological control strategy (the pest is eradicated) if this budget is larger than some value. Then we show that the optimal strategy to minimize worst case damage is to use the most frequent (and thus smallest) releases.
Autre [cs.OH]
RR-5849.pdf (207.57 Ko) Télécharger le fichier
inria-00070177 , version 1 (19-05-2006)
  • HAL Id : inria-00070177 , version 1
Ludovic Mailleret, Frédéric Grognard. Optimal release policy for prophylactic biological control. [Research Report] RR-5849, INRIA. 2006, pp.11. ⟨inria-00070177⟩
220 Consultations
123 Téléchargements
